Issue in connecting sub VI programs through the main program
Please explain in detail how to debug this error.
Message 61 of 92
(1,182 Views)
Hi ymanglik,
use probes, single stepping and highlighting
Message 62 of 92
(1,178 Views)
I'm really getting sick and tired of your attitude.  If you can't do your job, give it to somebody else who is willing to put a little time and effort into learning how to do it themselves.
Bill
CLD
(Mid-Level minion.)
Message 63 of 92
(1,162 Views)
Sorry for the previous mistake..........Now last time I want your help. As I have already made program of keithley 2410 for source V and Current I and it is woking also but when I give negative range of voltage so it returns "parameter out of range error".
So can you please tell me which command I should use to set voltage range. Here is the attached block diagram.
Message 64 of 92
(1,138 Views)
Hi ymanglik,
I'm sure the answer is to be found in the user manual of your K2410…
Message 65 of 92
(1,132 Views)
yes It is given like this:
:SOUR:VOLT:STAR <n>
:SOUR:VOLT:STOP<n>
For 2410 <n> = -1.05 to 1.05 Set I source level
                     = -1100 to 1100  set V-source level
                     = DEFault 0A or  0V
                     = MINimum -1.05A or -1100V
                     = MAXimum +1.05A or +1100V
Now I am not getting what should be right on the place of <n> because If I give :SOUR:VOLT:STAR -1100 & :SOUR:VOLT:STOP 1100 then it is giving numeric data error. So please tell me.
Message 66 of 92
(1,121 Views)
Sorry on the places of smiley I wrote command letter S.
Message 67 of 92
(1,120 Views)
Your code is pretty badly written and it seems you are getting an instrument specific error. Please use the VISA test panel to test each command separately before writing anything in LabVIEW. You need to debug what commands are correct and what commands are not correct first.
Message 68 of 92
(1,110 Views)
Hi Dennis,
debugging is not ymanglik's best qualification… 🙂
Message 69 of 92
(1,107 Views)
Hello GerdW,
No-one is perfect in starting to learn something. Everyone needs help.
ymanglik
Message 70 of 92
(1,073 Views)
