01-29-2014 11:18 PM
ymanglik2009@gmail.com wrote:
Hello GerdW,
No-one is perfect in starting to learn something. Everyone needs help.
ymanglik
While that is definitely true, it seems that you don't want help; you want someone to do it for you. You have all the tools, you have lots of advice. It's time to step up... or step aside.
01-29-2014 11:32 PM
01-29-2014 11:42 PM
Yes I have tried a lot but I am unable to understand. Its ok thanks a lot for your help.
01-29-2014 11:45 PM
02-04-2014 12:23 AM
Hello everyone,
As I have already discussed about my program which is working well with positive values of voltage but not accepting negative values & in my experiment i have to give 0 to -200 V bias voltage to the diode so I am not able to understand how to fulfill it. Which command should i use to do this or tell me any other method through which i can go for negative polarity.
please reply urgentlly!!!!!!
ymanglik
02-04-2014 12:52 AM
02-04-2014 10:13 AM
Hello everyone,
ymanglik
I don't understand. Isn't the Keithley 2400 a meter?
02-04-2014 01:02 PM
Set 0-200V and change polarity of outputs.
/Y
02-04-2014 01:13 PM
/Y
You're talking about a power supply, right? I just wanted to be clear because I am totally confused about what the OP is trying to ask.
02-04-2014 01:30 PM
