JKI JSON broken in LV2023 Q3?
I didn't use JKI JSON for a while since I started using JDP JSONText.
I have installed LV2023 Q3 on two different WIn 10 64 machines and can't get neither latest Version 1.1.X nor latest 2.0.X running.
When adding JKI's Unflatten or Flatten to JSON String to an empty VI, LabVIEW complains about several missing classes and vi's.
Can someone confirm this?
I removed and reinstalled the package, but no difference
Actor Framework
(333 Views)
Have you contacted JKI?
https://www.jki.net/
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(328 Views)
Since JKI's JSON has probably a large user base I think that it is unlikely that it's a general problem. If one or two people can confirm that it works on ther 2023 Q3 without problems I would consider tearing down my system and resetup everything.
Actor Framework
(317 Views)
Looks like an issue on your end.
Santhosh
Soliton Technologies
(277 Views)
