JSON JKI doble parser turns to default values
The main function of my program is to show the JSON data received from the serial (Arduino communication). VI program is attached.
To convert the string into a values i used "Unflatten From JSON String", a Variant To Data and a cluster to the variables definition. First of all i began with one json parser and it works with no modification as the file shows. But when i decide to send 2 different JSON data strings the "Indicator"s turns to the default values instead to keep the latest ones. Including the indicator of each variant in a state structure nothing change.
My aim is to update the values only when the JSON is the correct one (showing the last correct value in case of error), discarding the other. I suppose that using a global variable or storing the values in an array could solve the problem but i had been working on that 3 days without any advance.
One iteration of the serial is:
{"setupTime":-6144,"downTime":11267,"changeTime":1,"blowTime":14336,"upTime":-146,"surfaceTime":-769,"angleDown":0,"angleUp":1024,"cycles":-23552,"distance":3379,"heading":-8192,"beta":-15071,"shallowTarget":192,"deepTarget":257,"lattitude":1.12e-41,"longitude":6.92e19}
{"currentState":64,"accx":45,"accy":65,"accz":29,"magx":92,"magy":40,"magz":51,"GPSupdated":85,"currentLattitude":17.00,"currentLongitude":92.00,"pressure":52.00,"goalHeading":55,"currentHeading":55,"pitch":23}
Start Data Science
A
value: 0
D
value: 8486
T
value: 240
End Data Science
Thanks for the help 🙂
(3,447 Views)
Accepted by iscapla
I think you just need to use a feedback node to feedback the last known good values into the "Type and Defaults" input.
(3,423 Views)
It works. Thanks 🙂
(3,402 Views)
Hi Can you post the vi in labview 2014.
(3,082 Views)
