02-07-2017 09:16 PM
i generate simple VI to generate analog voltage, but i keep geeting signal even i stop the program. Anabody know the problem?
thank you
02-07-2017 09:57 PM
What do you mean? Do you mean that if you output a voltage other than 0, you still see that voltage?
That is not a problem. That is the way DAQ boards are designed. If you want the voltage to go back to 0, the you need to write that value using a DAQmx Write before you end your program.
02-08-2017 01:33 AM - last edited on 07-11-2024 03:07 PM by Content Cleaner
Do not use the DAQ Assistant, you can have much better flexibility and performance with the low level DAQmx VIs: https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
02-08-2017 09:35 AM
yes, i need output the voltage let say (2 V) for 2 mintues and then go back to 0V. i'm outputing the voltage to micropump i want to run the pump for 2 mints and stop. but in my case keep getting the voltage even i stop the VI and even exit the LabView program.
Thank for your help
02-08-2017 09:52 AM - edited 02-08-2017 09:53 AM
Hi Mo,
set the output to "2", then wait for 2mins, then set the output to "0"…
You might want to learn about state machines. They can make your life easier! 😄
(For your simple requirement even a FOR loop with an array input of [2, 0] will do.)
02-08-2017 08:40 PM
Sorry for the to much quistions.i'm new to Labview and i have to use it.
Is there any example to do that?
thanks
02-09-2017 02:24 AM
Hi Mo,
In the header of the LabVIEW forum you will find several links to learning resources.
Just use them!
LabVIEW comes with a lot of example VIs. Just use the example finder in the help menu! (Maybe after doing those beginner courses mentioned above…)
02-16-2017 01:36 PM
Thank guys for your help. I got it.
