Keeping the data I enter in my VI after I close the V, without it resetting to default?
@Dr_Dean wrote:
Clicking Save current values to default works.
I had read the title "without it resetting to default" as meaning that you didn't want the default values to change...
I guess more information was needed about your requirements.
Careful about setting values to default because you can end up with a really large VI file size when you set a chart/graph or array with default values.
Cheers
Message 11 of 11
(1,192 Views)
