Keyesight Oscilloscope DSOX-3000 Series Can't Measure Continuously at Measurement
Dear Sir. Hello
I'm used to using a DMM called 34401a, but I'm not used to using an oscilloscope.
Currently, I'm going to make a real-time measurement vi using Labview with an oscilloscope called Keysight DSOX-3054T.
However, when measuring using the while loop using the example file, the oscilloscope stops and executes as shown in the image below, and the measurement data graph is displayed on the labview interface, and real-time measurement is impossible.
[OSC Operation Video]
Unlike the video, I want the oscilloscope to keep running constantly and the measurement data on the oscilloscope and the graph of the measurement data on the vi interface to be measured and displayed in real time, but I wonder if there is a way to solve it.
I look forward to hearing from you
I wish you all the blessings of God
(490 Views)
Are you using the driver from Keysight 2000 3000 4000 X-Series?
There is an example of continuous measurement. Have you checked it out?
(475 Views)
Yes, when it works through that example, it works like the image above. I want the run-stop to operate in a consistent run-in state, not blinking.
(427 Views)
Hi Seto,
You are using a scope now, not a DMM!
Scopes run, trigger and present the result. Then you repeat with run, …
(422 Views)
