This widget could not be displayed.
LED push button
Need help in resolving below given 2 issues:
1. I have a string Combo box(dropdown) having options A,B,C &D. But i need to make these options as  LED push buttons. Is there a way to make a boolean to pass a string value? When pressed A, it should pass the string associated with it(say "Pressure") to the output and when pressed B, it should pass string "Temperature".
2. I have a device say P1.  it polls for status and value in 2 iterations of a for loop(iteration 0 checks status and iteration 1 checks value). when I create a table, i get 2 entries of the same device, one with status and other with value. I want both value and status in a single entry of the device in the table. Can this be done? If yes then I need to make a subVI of this so that I can make a "show table" button in the mainVI which will display the table only when clicked.
Please let me know if the above details are not clear. Looking forward to your suggestions and inputs.
Thanks & Regards,
Sushruth.
Message 1 of 26
(5,557 Views)
Hi Sushruth
A possible solution for your #1 (String from Boolean LED.vi) attached.  You will need to set the Caption text of your LEDs to the text you want to pass out ("Pressure", "Temperature" etc.).  I have used Caption, but Label, Tipstrip, Description or any of the other text fields could be used instead.
Not sure I really understand #2.
Steve
Message 2 of 26
(5,545 Views)
For your 1st question you can easily do it by creating event and placing the booleans seperately or in a cluster and passing the required string.
Try posting your code for better solution.
Message 3 of 26
(5,545 Views)
Thanks a lot for the Inputs. I am currently working the the methods for  question 1. I will post the code asap.
Question 2--The table I have designed now is like this:
Device
Status
Value
Unit
T1
Good
T1
15
T1
°C
This is because i get the data for Status, Value and Unit in 3 different iterations though in each iteration, as you can see the device is the same. I want to present as below:
Device
Status
Value
Unit
T1
Good
15
°C
Message 4 of 26
(5,541 Views)
You check whether the device is there already in the table. Then try to use the
invoke node: set cell value for inserting in the table by giving index. This will replace the table entry.
Hope this helps..
Aarthi
Message 5 of 26
(5,533 Views)
Either "Append True/False String" or Select can be used to pass a string from a boolean
Message 6 of 26
(5,503 Views)
LabVIEW 2012
Message 7 of 26
(5,477 Views)
A radio button would seem to fit your requirement. Wire it to a Format Into String and you are done.
You really need to post your code to see how you are building the array for the table.
Message 8 of 26
(5,470 Views)
Thanks a lot for the inputs. Q1 has been resolved. I just made it into an event case. Something like this:
Its working as I wanted. Regarding the Q2, I will upload the code as soon as possible.
Sushruth.
Message 9 of 26
(5,464 Views)
Message 10 of 26
(5,462 Views)
