LV 2015 LabVIEW load error code 1: LabVIEW load error code %Id: %p
I got this message today after my computer crashed. I'm trying to open a VI, and there is no recovery option. Am I out of luck or is there some method of recovering it?
(3,407 Views)
Accepted by Speaks
Hi Speaks,
Yes, sure!
Get the VI from your backup drive.
Or even better: check out an older version of this VI from your source code control repository!
Or to put it in other words:
Get used to create backups. Not just for LabVIEW VIs, but for all important data you don't want to lose.
For source code you should use some SCC software, like SVN or GIT…
(3,381 Views)
So then the answer is no, I'm as screwed as I am stupid. Thank you for making that so clear.
(3,357 Views)
