01-18-2019 05:17 AM
I installed LV2014 (32bit) Home bundle into 64 bit Windows 10 Computer. LV was installed OK but the DAQmx drivers do not install. I have tried several DAQmx packages but no chance to install LV2014 32 bit application development support. Does LV2014 home bundle support DAQmx? I have NI data acquisition card and would like to play with it at home.
I have tried DAQmx 14.x, 15.x, 16.x and 17.x packages. Always the same that 32 bit LV2014 application development support cannot be added. Please see the attached Picture:
The newest DAQmx has no more LV2014 support.
BR,
Ilkka
01-18-2019 08:33 AM
That green check mark indicates that you already have a newer version of DAQmx installed. Did you install DAQmx 18? Completely uninstall DAQmx and then install the version you want (probably the 17.x version).
01-18-2019 08:40 AM
yes, there was the newest DAQmx 18.6 in the Computer. I uninstalled it but maybe not competely. I try today later again..
01-18-2019 03:26 PM
Thanks.. I uninstalled all NI sw and installed LV Home Bundle and DAQmx 17.6 after that. Everything is OK now and works well. I will restore the rest of the NI stuff later.
Have a nice weekend,
Ilkka
