LVRTE 2012 install refuses because of higher versions
LVRTE 2012 install refuses because of higher versions already installed
see attachement
(2,519 Views)
Accepted by kdCMC
probably LVRTE 2012 is installed, but not visible in programs and features NI programs...
In C:\Program Files (x86)\National Instruments\Shared\LabVIEW Run-Time, they are all visible...
perhaps another reason why the LV application quits/dissapears without notice... (e.g. security dongle)
(2,509 Views)
Accepted by kdCMC
Hello kdCMC,
Did you resolve the issue this way?
Did you see the Run-Time Engine (and/or other components) in your NI MAX Report?
Kind Regards,
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,456 Views)
