LabVIEW 2011 is out!
Thank you Dennis,
I will give this a try.  I was told by an Applications Engineer that 9.3 was still the latest and was compatible with 2011.
Message 21 of 24
(2,378 Views)
LV 2011 FPGA module patch f1 already out! Amazing... I was about to report that a NiFpgaLv.dll could not be loaded and prevented me from opening past projects but the patch seems to have fixed that problem!
Kudos to NI for the quick fix!
Message 22 of 24
(2,377 Views)
DAQmx 9.3 is not compatible with LabVIEW 2011, according to its readme.
NI Application Software Versions Supported by NI-DAQmx and the DAQ Assistant
LabVIEW 8.5.x, 8.6.x, 2009, and 2010
LabVIEW Real-Time Module 8.5.x and later (including 2009 and later)
LabWindows/CVI 8.1 and later (including 2009 and later)
LabWindows/CVI Real-Time Module 8.1 and later (including 2009 and later)
Measurement Studio 8.1 and later (including 2009 and later)
LabVIEW SignalExpress 2.x and later (including 2009 and later)
DAQmx 9.3.5 (which will be on the Fall 2011 driver DVD and is available through NI Update Service) and DAQmx 9.4 both have support for LabVIEW 2011.
Best Regards,
John Passiak
Message 23 of 24
(2,327 Views)
John,
I agree. I saw the same info which lead me to request help from NI support.  I have 2011 up and running with DAQmx functions after installing 9.4.
Thanks to everyone for replying.
Message 24 of 24
(2,312 Views)
