01-14-2023 01:23 PM
if anyone is interested in the solution:
download driver from here:
https://www.keysight.com/us/en/lib/software-detail/driver/816x-vxi-plugplay-driver-112417.html
and follow the instructions here:
01-14-2023 02:30 PM
Someone might be interested in the future, so you should mark your post as the solution so they know you found an answer. That's just the other half of you being thoughtful enough to post your solution 🙂
02-10-2023 12:37 PM
After re-installing everything and then installing the Agilent/Keysight drivers as described in this solution, it worked.
Thanks!
