LabVIEW 7.1 freezes (remains unresponsive) when opening block diagrams
While opening some bigger VIs (block diagram) LabVIEW hangs for a while and does not respond for several minutes. It turns to normal after several minutes and any kind of interaction with the block diagram in question makes it freeze again.
Did anyone have a similar problem? Is there a way to fix it?
Thanks.
(3,300 Views)
This has happened to me while using older equipment.  When that happens, open the block diagram and go make some coffee.  By the time you get back (5-10 mins), the block diagram is ready to go.
The main issue is RAM, you should have as much as possible.  It's very cheap these days.  Or it might be your video card; if it's onboard that might be your slowdown.  It might just be time to upgrade your computer.
If hardware isn't the issue, I am as lost as you.
(3,285 Views)
Accepted by mgerceker
I have seen LV getting slow on older hardware when using nested clusters on a tab control. But this is on the front panel.
It could also be some large default data set (again FP). How big is the size of your vi (on disc).
One more thing to watch out would be the run arrow, if it is broken during the hang, it is due to a recompile. In this case mass compile could do some improvements.
Also monitor CPU usage and Memory consumtion with the task manager (or similar tools if not on win).
Do you have old HW or OS? Can you share a sample vi that is so slow? Any clues about bad coding (overlaping, nested structures) that could cause subsequent redrawing of the window?
Felix
(3,279 Views)
Felix covered most of the first things to check.
Also check for old non-existing devices in MAX if there are DAQ task controls on the FP and I believe thee is another setting for VISA.
Ben
(3,269 Views)
Here's the sysinfo.
OS Name    Microsoft Windows XP Professional
Version    5.1.2600 Service Pack 3 Build 2600
OS Manufacturer    Microsoft Corporation
System Name    MG-LAPTOP
System Manufacturer    Dell Inc.
System Model    Precision M65
System Type    X86-based PC
Processor    x86 Family 6 Model 15 Stepping 6 GenuineIntel ~2327 Mhz
BIOS Version/Date    Dell Inc. A10, 10/16/2008
SMBIOS Version    2.4
Windows Directory    C:\WINDOWS
System Directory    C:\WINDOWS\system32
Boot Device    \Device\HarddiskVolume2
Locale    United States
Hardware Abstraction Layer    Version = "5.1.2600.5512 (xpsp.080413-2111)"
User Name    NEURO-KINETICS\MGerceker
Time Zone    Eastern Daylight Time
Total Physical Memory    4,096.00 MB
Available Physical Memory    2.01 GB
Total Virtual Memory    2.00 GB
Available Virtual Memory    1.95 GB
Page File Space    5.09 GB
Page File    C:\pagefile.sys
Recompiling the VI helped. Thank you for your help.
(3,235 Views)
