LabVIEW Modbus Library
Hello all,
I want to communicate with Modbus instrument via serial interface
Library provided here on this link-  http://sine.ni.com/devzone/cda/epd/p/id/4756 opens with LabVIEW 8.6
I have previous version of labview -  8.2.1
How to make it open with labview version that I have?
Kindly educate me in this regard.
Also enthusiasists provide me libraries you successfully built if there is no other way.
Thanks & Regards,
Snehal
CLAD
(2,519 Views)
Check carefully, the link you provided has a ZIP file to be downloaded, which contains MODBUS library for different versions of LabVIEW (including for LabVIEW 8.2).
MODBUS Library for different LabVIEW versions
Well in future if you want someone to upgrade/downgrade LabVIEW code for you, ask someone here.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,506 Views)
Thank you for providing this link
I was about to post this question regarding downgrading LabVIEW.
Thanks & Regards
Snehal
(2,476 Views)
