LabVIEW+Nexys4 (FPGA Artix 7)
Hi every one!! I'm new with LabVIEW, but I have been working with my Nexys 4 for a time, and I want to use like a DAQ, because I don't want to buy one.....there's some way to use it?
(3,831 Views)
Yes.  Plug it in and use it.
You probably have to do some more programming than that.
Do you have a specific question?  Without asking any real questions, it's impossible to be able to help you.
(3,829 Views)
LabVIEW FPGA only works with NI hardware (with very few exceptions). What are you trying to do?
(3,810 Views)
Hello Cvillasenor,
As altenbach explained, the Digilent's Nexys 4 board it's not officially supported with LabVIEW FPGA. But you can still use Multisim PLD Designs, I´m not sure what kind of projects you are trying to implement, but may be this can be helpful to you:
Getting Started with Digilent Boards in Multisim:
www.ni.com/white-paper/14871/en/
Digital Comparison Logic:
http://www.ni.com/white-paper/14960/en/a
I hope this help you, best regards.
David P.
Applications Engineer
www.ni.com/soporte
(3,736 Views)
Hi, I want to do a DAQ with the FPGA, I want to get some data from a sensor, send it to LabVIEW, get a graph, as I move a servo with the FPGA and set a little memory shift
(3,715 Views)
