[LabVIEW Tutorials] Programming an Arduino using LINX
@Peterpark99 wrote:
Hi, Sin
Have you ever used HC-05 (bluetooth Module) connected with Arduino Uno to communicate with Labview ? I'm having a trouble with Linx when i try to Blink the LED (sorry about my bad English). It keep show up error 5003, error 5001... I searched on google everywhere but still not found a proper solution. Can you help me out with this ?
Appreciate in advance.
Yes, I have used these devices before and there's a couple things that you must do:
You need to connect HC-05 to your computer using a USB to Serial adaptor and then configure the HC-05 using a terminal program like Tera-term and the "AT" commands
  1. Configure Master/ Slave mode
  2. Configure communication settings (baud, bits, parity)
  3. Configure the paring
Here's a link to the HC-05 Wiki
=== Engineer Ambiguously ===
Message 61 of 72
(2,188 Views)
I load firmware from Linx to Arduino Uno by USB cable, then remove USB and connect my HC-06 to Arduino Uno. I paired HC-06 with my PC using a Bluetooth USB CSR 4.0. Then I run a sample Linx - Blink, I choose COM5. But in the end the Error still there. Please help me!
Message 62 of 72
(2,142 Views)
I use HC-06 now
Message 63 of 72
(2,141 Views)
Can someone help me, how to fix this, I chased it down and stuck here.
Message 64 of 72
(2,089 Views)
Hi Sin!
Thank you for these videos. I saw someone else in the forum share a similar issue, but I am trying to control a bipolar Nema 23 stepper with a StepperOnline driver in the same fashion. I recognize the logic in your video, but I am having trouble translating it into my system. Any chance you could provide some guidance?
Thanks in advance!
Message 65 of 72
(1,960 Views)
Hi Sin.Your videos are very useful.I have a problem and i wanna share with you.I want to connect my Esp32 to labview as completely you did for Esp8266.I have all modify files and i arrange them as you did and i execute an example with arduino but i get an error like that: 
Is there anything you suggest that I can try.
Mehmet.
Message 66 of 72
(1,695 Views)
Hello!
I have one question about this sonar project. I understand the LabVIEW part of, but the arduino doesnt need also to be programmed in arduino ide? I checked your github and I didn't find anything about arduino ide, only the VIs.
Thanks!
Message 67 of 72
(1,584 Views)
Linx/Hobbyist comes with already built firmware for the arduino that works with the labview API. Once you go through the device setup from the tools menu entry you'll have an arduino that works with the toolkit.
~ G stands for Fun ~
Helping pave the path to long-term living and thriving in space.
Message 68 of 72
(1,572 Views)
It depends what you want to do. Yes Linx comes with a firmware for quite a few Arduino boards. This firmware remotes the Arduino hardware to make it available over the serial port or TCP/IP through the Linx interface. Basically every single input you want to read or output you want to write goest through this route from your host program on the PC:
PC->LabVIEW->Linx API->serial or TCP/IP->Linx server in the Arduino firmware->Arduino hardware
So it works but of course is not very fast. Depending on what you want to do this can be enough. If not, Linx also allows to implement custom commands but that requires modification of the Linx firmware (and the according C++ code) to implement those custom commands on the Arduino side. It's very doable but not your average starter project to learn to use Arduino.
Rolf Kalbermatter
My Blog
Message 69 of 72
(1,568 Views)
Hi
i watched your demo video.
I downloaded the sample VI from the following location and executed the VI.
https://github.com/SINConsulting/LabVIEW-Basics/tree/master/LabVIEW%20Basics%20Examples/LabvIEW%20BA...
When I run the VI, the motor doesn't rotate as fast as in the demo video.
I will attach the video of that time.
+5V power is supplied externally.
My Labview is Labview2021.
I changed the step speed with the knob. But the rotation speed does not change.
i don't know what to do.
Could you give me some advice for improving the rotation speed?
BestRegards
Message 70 of 72
(1,506 Views)
