LabView 7 Express : connect to a projector
Hi there,
Does anybody know how to connect a projector to LabView 7 Express?
Thanks in advance,
Carlos
(3,665 Views)
Your question is too vague. Different projectors have different capabilities and I/O ports. Does it have a serial port? Does it have a USB port? If it has a serial port do you have the documentation on the communication protocol? If it has a USB port does the vendor provide a driver for it? Does the vendor provide a program for the projector? What are you trying to do with the projector?
(3,658 Views)
You're right. I'll reformulate the question when I know everything about it. Thanks for your reply 🙂
(3,652 Views)
Ok, the projector I need to connect to is in the end a mini usb monitor:
http://www.jpcentury.com/pro_con.aspx?id=P_00000039
Specifications
Product name
4.3” Mini USB Monitor
Model number
LCD-4300U
Interface
Based on USB/Rev2.0
Pixel
WVGA 800 x 400
Brightness
200 cd/m2
Frame Angle
45 / 65 / 65 / 65
Colour
24 bit 167000
Dimension
127 mm x 77 mm x 17 mm
Weight
130 g
Voltage
+5V  500mA (below) ( 2.5W below )
Supported Machine
Windows:
Supported OS
Windows Vista   /   WindowsXP ( SP2 after )
C ontents
l           4.3 Mini USB Monitor
l           Special USB Cable
l           CD software
l           I nstruction manual
Temperature and Humidity
5 ~ 35 ℃ 、 humidity 20 ~ 80%
* this machine should be used in the operation range of the connected PC.
  • Functions and Applications
      1)   USB Powered No extra power supply is required   2) Great picture quality The best Japan-made LCD panel is used 3) Light Weight Weight only 130 g 4 ) Different viewing angles Up to 3 different frame positions can be set-up 5) Easy Removable Convenient size for taking anywhere
    Thanks in advance,
    Carlos
    (3,637 Views)
    I need to display images in that monitor. I have them as png files so to get them I can use the vi called "Read PNG File", but idk how to use the image data to display it on the other monitor (and only the image, centered in a black background if it doesn't fit)
    (3,611 Views)
    Accepted by Carlos C. G.
    (3,604 Views)
