LabView Help
@James.M wrote:
The way I would do this that's pretty simple is this:
  1. Build array of 1-69
  2. Use a For loop to loop N times for how many numbers you want to pull out
  3. Pass your array to shift registers on the For loop
  4. Within the For loop, use random number (scaled to be between 0 and array size minus 1) to delete an element from the array and pass the smaller array back to the shift register
  5. Output the deleted elements from each loop of the array and you have your lotterty numbers.
It is easy than that
Now, explain that to your instructor and earn the  A
"Should be" isn't "Is" -Jay
Message 11 of 30
(1,745 Views)
Riffled. That's something new!
I'm not sure if you meant to make a mistake in the code or not.
Cheers
Message 12 of 30
(1,786 Views)
Apparently Bill is doing a great job of helping students do thier own homework!
For those of you that did the "College" thing--- when should I avoid doing homework?  Yup- March == Spring break and handing in assignments studii should have been working on before they partied.
Thanks RF
@ James- Riffled is not new---- It is no longer biased!  Search for "riffle is biased"
Message 13 of 30
(1,767 Views)
How did you get that thing in the middle?
Message 14 of 30
(1,694 Views)
So here is my second attempt to post my VI. So Im trying to figure out what to do next. I need to create a lottery generator simulator. Numbers must be betwen 1-69 and they cannot repeat.
I took a screen shot of the VI just in case it's blank again.
Message 15 of 30
(1,666 Views)
Hi Solrac,
ctrl-space, then type "Riffle"…
(In the German LabVIEW version it's called "Mischen".)
Message 16 of 30
(1,680 Views)
Can you tell me what a riffle does so i know how to explain it to my teacher.
Message 17 of 30
(1,677 Views)
Also how do you get that last part?
Message 18 of 30
(1,669 Views)
Solrac, this information is an easy Google search away. I will admit with this one that Riffle has pretty bad LabVIEW help information. It uses the word Riffle to describe Riffle.vi.
Cheers
Message 19 of 30
(1,665 Views)
Riffle takes an array of numbers and randomly rearranges them.
GCentral
Message 20 of 30
(1,658 Views)
