LabView executable showing different analog input values than original project
hello,
My project is running fine and showing correct readings. But after I made executable and run it it shows different values. For assurance I run my original VI and it worked fine. Now I am unable to understand the problem. I made executables before but this never happened.
Any suggestion will be helpful.
(683 Views)
Too vague to guide you anywhere. What is your code architecture look like? what kind of hardware do you interface with? what exactly do you mean shows different values?
Santhosh
Soliton Technologies
(644 Views)
Sorry for incomplete information. I am using NI-USB6251 for measuring input signal of 1KHz. In VI it shows 1Vpp but when I made executable it shows 2Vpp and above. I used standard example code of hardware input output from examples.
(600 Views)
