02-19-2013 05:45 PM
I am looking for the DDE library @ labview\vi.lib\platform\dde.llb with no success. It appears that I do not have that library. Is there any way I can get dde.llb elsewhere?
Thank you in advance,
-Jason
02-20-2013 01:59 PM
Hi Jason,
First try to repair your LabVIEW software by going to add/remove devices in the control panel. If you right click on the "national instruments software" and choose "uninstall/change", you can choose repair option. This process will look for whatever is missing in your LabVIEW and add it. Good luck
02-21-2013 03:26 PM
@ Edna, I tried repairing but still did not get the dde.llb. Is it possible that my trial version does not come with it?
In any case, before I can purchase full Labview I need to know if my current VI works. It requires the dde.llb, can someone provide that to me?
Thanks in advance,
-Jason
02-21-2013 04:04 PM
I have LabVIEW 2009, and dde.llb is there.
02-21-2013 04:25 PM
Could you attach that library for me so that I can put it in my directory?
02-22-2013 03:20 PM
Jason what LabVIEW version are you using? We first need to make sure that version includes dde library. Thank you!
02-22-2013 04:14 PM
I am using Labview 2012 (64-bit) version on Windows 7 Professional (64-bit).
02-25-2013
12:40 PM
- last edited on
02-05-2025
02:08 PM
by
Content Cleaner
Hi Jason,
I beleive that you can get the library by uninstalling/reinstalling your LabVIEW from either the DVD you got or by downloading it again from our website(link included). Unfortunatly, I can't just post it here for you.
https://www.ni.com/en/support/downloads/software-products/download.labview.html
02-25-2013 02:11 PM
Hi Edna,
I figured that the dde library wasnt present in the 64 bit version. I installed the 32 bit version and the dde library came with that.
Thanks for your help.
-Jason
02-26-2013 08:36 AM
Awesome Jason. Glad that worked out for you!
