Labview AF subpanel
Hello I want to develop a project with AF framework. It has an interface which sepreated into 4 Sub_Panels. I want to create 4 actors with front_Panel in actor core.vi dependence and bond them to Sub_Panels. How can I bond Actors to Sub_Panels?
(3,242 Views)
Hello Sailfish
As AF are base on OOP. In order to bound a sub panel to one actor (lvclass), the .ctl of the class should at least contain the refnum of a subpanel.
The methods used in each class will targeted the subpanel you "passing throught" your refnum.
Best regards.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(3,208 Views)
Hello Sabri.jatlaoui: Thanks for your answer. Using a refnum is a good way to bound an actor to a Sub_panel. But what I want to bound an actor to a Sub_Panel is to display the actor core.vi front_panel in the sub_panel. As you see, to show a VI’s front_panel in Sub_Panel it will open and run a VI and then pass the VI’s refnum to Sub_Panel’s method (Insert VI). In AF, an actor’s actor core.vi is called defaultly in launch actor.vi . Can I open the actor core.vi and pass it’s refnum to Sub_Panel’s Insert VI method without running it in Pre_lauch.vi
(3,167 Views)
There is a demo project called the "Feedback Evaporative Cooler". It uses Actor Framework and two swapable subpannels.
You can get to it from File >> Create Project
(3,144 Views)
That is great. Thanks
(3,113 Views)
