Labview Append Report Text VI
Hi
Is there a way to get labview "Labview Append Report Text VI " to select a particular sheet in my ecxel document, i have a ecxel document with two sheets, an i can only get it to write in the first sheet, and that is working correctly.
I can't find a guide that addresses this.
Is there anyone who can help 😁
(2,408 Views)
Accepted by Andelaus
You need to use the Excel Get Worksheet VI to set the current worksheet, then use the Append Report Text to that worksheet. Call the sheet either by number or by name (not both).
See..
(2,372 Views)
Thank you, i will try that right away 😁
(2,333 Views)
It was incredibly simple to do, I don't understand that I didn't see it myself.
But thanks for the quick reply 👍
(2,330 Views)
