Labview Basic Questions
i have 2 Questions:
i want plot some plots like this: http://elektroniktutor.de/bauteilkunde/bt_pict/trkennl.gif
now all my plots have the X in the right position. Can i twist it to the left?
If i negate the X Side its looks ok but the X legend is wrong (because its negative).
I haave seen often in NI Programs that they have an run and stop button.
How can i implement this?
the programm runs all time....with start i start the task and with stop i end the task (but the program will still run)
i only yfound the Funcction "Stop" but it terminate the whole session.
Message 1 of 13
(4,042 Views)
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
GCentral
Message 2 of 13
(4,033 Views)
i have done the 3 and 6 hour introduction....
Message 3 of 13
(4,029 Views)
And they didn't teach you to use a stop button?  If you are using the Run Continuous button in the toolbar, stop doing that.  Just use the normal run button.
It would help us diagnose your problem if you posted your code.
GCentral
Message 4 of 13
(4,021 Views)
i will do it like : http://www.eng.auburn.edu/~niuguof/2210labdev/html/_images/bjt-iv.png
if i press run...the measure start....if i press stop the measure stops.
But the Program runs all the time.
Using the Buttons "run", "run cont." and "stop" i doont wanted to use
Message 5 of 13
(4,016 Views)
Accepted by topic author nkritsch
Hey crossrulz beat me to it.
Back to the posters issues.  Yeah don't do what you code is doing.  Try what I've attached.  It is your program with some improvements.  I think the functionality should be the same.  Just click Run Once.  Then when you want to run click the start button.  To stop click the stop button again, or if the condition is met that normally would stop the VI happens, it will stop on its own.  Also to stop the application click the close button (the red X) like a normal program.  Of course if a test is running the stop will be ignored until the test completes.  You can add your own abort test button if you'd like.
Other general comments.  Don't use dynamic data types, don't use express VIs and DAQ Assistant.  Don't make the block diagram have to scroll in more than one direction.  Don't use run continuous.  Don't use Abort VI toolbar button or primative.
Message 6 of 13
(3,976 Views)
@crossrulz wrote:
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Two more useful links that have been recently updated/added
learnni.com (currently just for LabVIEW)
ni.com/gettingstarted (which links to the LabVIEW Basics topic crossrulz suggested)
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments | Certified LabVIEW Architect
Message 7 of 13
(3,905 Views)
That is fantastic, I'll be adding it to the list of recommended links for new users I post.
Message 8 of 13
(3,874 Views)
thanks to your code
How do you make it that when you "run" the program the front panel appers on a new window?
why its bad to use DAQ Assistant? in the introduction it was told that we should use it.
do you know how i can tell the XY Graph that i dont want get the Axes (of the X or Y) in the one direction, but in an other direction?
Message 9 of 13
(3,836 Views)
I'm not sure what you are asking here.
The DAQ Assistant is good for very quick programs where you are just quickly getting some data and showing it on a graph.  If you need to do any more than that, go to the actual DAQmx API.  The DAQ Assistant has a lot of inefficiencies that doesn't make it good for non-tiny projects.  And its output is a Dynamic Data Type, which we HATE.  The reason we detest the DDT is because it encapsulates the actual data.  You will have no clue what the is just by looking at it.  And we've seen some really messed up code because of that.
If you weren't use the DDT, I would likely say to use Transpose 2D Array.
GCentral
Message 10 of 13
(3,811 Views)
