Labview-C # rotate bitmap image
transparent in regards to the .vi's frontpanel background?
I don't think that's possible with the dotnet picture box, use the built-in LabView image to achieve this.
within the dotnet picture box, you can set each pixel's alpha channel from 0 to 255
e.g. all pixel of the rotated image to alpha = 255, all the black background pixels to 0
or vice versa
Message 11 of 16
(884 Views)
like this
Message 12 of 16
(860 Views)
 Alexderjuengere thanks I solved this problem with a different method.
Message 13 of 16
(842 Views)
Hi, @constructionworker,
For the benefit of the next person to come along, could you please answer these questions?
  • What method did you use to solve your problem?
  • In your particular case, what made your method preferable to @alexderjuengere's solution?
joeorbob
Message 14 of 16
(830 Views)
 Joeorbob
I am trying to add the bitmap image to the Gmap.Net map. I need to rotate the image. but after doing it with the method alexderjuengere showed, I could not add it to the example made with Gmap.Net. I ran into some problems. I could not see the image as transparent. I commented on the C # examples made with 'Gmap.Net.Windows.dll' to Labview. Now I can transparently add a PNG file I want to the map and rotate it. This is how I solved this problem.
Message 15 of 16
(791 Views)
Thank you for the vi, after continuous operation for a period of time, the program prompts out of memory, I think may be MemoryStream no release, I try to release it but doesn't work,  can you help me,Thank you !! 超内存.PNG
Message 16 of 16
(683 Views)
