Labview: (Hex 0x464) VI is not loadable.
I have an LabVIEW 2018 executable built on a Win7 pc. It runs fine. I ran it on another Win7 pc and a Win10 pc and it runs fine. However, another Win7 and Win10 machine have the following errors. The PCs that fail do not have the LabVIEW 2018 Development installed, only the 2018 Runtime Engine. The app has the following dll dependencies, Advapi32.dll, kernal32.dll, lvanlys.dll. Any suggestions how to fix this?
(5,407 Views)
At the first - try to remove the checkmark from the "Enable SSE2 optimization" checkbox in the buld spec (if enabled).
(5,391 Views)
Are there any x86 processors out there that don't use that?  I feel it is a symptom and not the problem.
Bill
CLD
(Mid-Level minion.)
(5,382 Views)
I have LabVIEW 2018 32 bit installed. I do not see the Enable SSE2 Optimization option.
(5,371 Views)
Accepted by davidhi
Looks like the issue was with the LabVIEW 2018. I just updated with 2018 f2patch and the app is now working.
(5,348 Views)
Don't forget to mark your post as the solution.  It will definitely help others!
Bill
CLD
(Mid-Level minion.)
(5,345 Views)
Experienced the same problem. Runs fine on development computer. Popup this error on computer only with LV18 runtime.  One compiled app initially runs fine, then after disabling an indicator also started this error. Everything fixed after installing f2 patch through NI update service.
(4,259 Views)
