Labview call TestStand API
I want to use labview to create User Interface(not use teststand user interface)
The Execute Example only provide full sequence result after excution over.
How can i control single step and get single step result?
(758 Views)
If you want to see the report before the execution finish, configure TestStand to generate report "On-The-Fly Reporting...".
From TestStand menu bar => Configure => Result Processing..., on the popup menu, make sure "On-The-Fly Reporting..." is checked.
For more detail, see
TestStand Report Generation and Customization
https://www.ni.com/en-us/support/documentation/supplemental/08/teststand-report-generation-and-custo...
George Zou
(741 Views)
Thanks for your answer.
For create a custom user interface, i prepare to use another program language, So I want to use teststand api to achieve this function. But i cannot find a detail api manual, so I want to find some help here
(689 Views)
