Labview driver for LeCroy WaveAce oscilloscope?
I am not sure if you are referring to the drivers as they relate to Labview or if you are referring to the drivers that were on Lecroy's install CD.  If it is not related to Labview than I would reccomend that you contact the manufacturer directly.
Jacob K
Applications Engineer
Jacob K
Message 21 of 28
(1,856 Views)
Does it works only via lan or someone tried it also via usb?
Message 22 of 28
(1,713 Views)
I am also a little disappointed that there is no Labview drivers for this waveace instruments. Is there any progress on this?
cheers
Julian
Message 23 of 28
(1,676 Views)
Hi All,
Just in case you are wondering there is a WaveAce LabVIEW driver on the LeCroy website for download. I think it only works with the 1000 and 2000 series.
Phil
Message 24 of 28
(1,493 Views)
Has anyone tried the LeCroy WaveAce 1000/2000 LabVIEW drivers on a WaveAce 222 or similar model?  I downloaded the drivers and they are written in LabVIEW 2012.  I have LabVIEW 2011 so I was not able to get them to run on may computer.  LHP
Message 25 of 28
(1,458 Views)
Welcome to the NI forums!
This thread isn't the most active anymore, you may want to post a request to our version conversion forum to see if a community member can make the VIs into an older version. Best of luck!
Nathan Murphy
Message 26 of 28
(1,438 Views)
Has there been no update on drivers the WaveAce 200 series?
We have a few and it would be quite nice to be able to use them with LabVIEW.
Message 27 of 28
(1,127 Views)
Hello All,
Sorry, there are not any LabVIEW drivers for the WaveAce 100/200 series Oscilloscopes available from TeledyneLecroy.
There are only the ones for the WaveAce 1000/2000 series.
The two scope series are different hardware platforms and use different technologies so the driver is not compatible with the older discontinued series.
Leonard Brown
TeledyneLecroy
1-800-553-2769
Message 28 of 28
(1,123 Views)
