Loban,
Khalid is correct, this toolkit will install into the Addons portion of
the pallette. It is also not visible until after you have
restarted your computer, so if you are not seeing the pallettes, try
rebooting your computer and checking again. Which version of
LabVIEW are you using? I currently have the ECU Measurement &
Calibration toolkit installed in LabVIEW 8, and I can see all the VIs
just fine in the Addons pallette.
Jason S.
