01-31-2023 08:57 AM
@rolfk wrote:
You are all barking up the wrong tree here.
I figured that much.
I also expected you'd know the details.
02-02-2023 01:39 PM
A few years ago I experimented with Windows 10 on ARM and LabVIEW. Here was my conclusion which basically is that only LabVIEW 2016 could be used due to SSE optimizations, and that the runtime engine needed to be manually installed. I was able to get code running, and publishing LabVIEW VI front panels to web pages using WebSockets.
https://forums.ni.com/t5/LabVIEW/Labview-for-raspberry-pi-3/m-p/4031067#M1155884
At the time several limitations existed with the Windows 10 on Pi configuration, which I think have been improved since then.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
02-03-2023 03:41 AM
Any chance MS will pick this up?
LabVIEW can't be the only application with this problem.
02-22-2023 11:00 PM
Hola, pudiste correr los ejecutables de labview en la PI?
