11-07-2014 11:09 AM
LV2013 PDS is opening all VIs in Run Mode. This is a global problem, not specific to one or a specific number of VIs.
If I create a new VI, save it, close it and re-open it, it's in Run Mode, not Edit mode. Nothing is set to Run When Opened, nothing is set to be locked without a password.
It's only on this installation; if I take my code to another machine, there's no issue.
I have deleted the labview.INI file, but the behavior repeats itself.
Any ideas?
11-07-2014 11:18 AM
Check the permissions on the containing folder. Is something set "Read Only?. What about SCC?
11-07-2014 11:35 AM
SCC is not configured; I use perforce, but it's not configued to use it or to treat read-only as locked. I have also checked out all the filed ahead of time with P4, so LV never sees them locked. The folders themselves are not read-only.
Also, I have created VIs outside of my P4 folder, and I have the same trouble.
Example:
Launch LV: Create a blank VI (comes up in Edit mode).
Save to Desktop (not within P4 control) as test.VI
Close
Open test.VI ---> It's in Run Mode
I have never seen this happen before.
11-07-2014 12:08 PM
Example:
Close
Neither have I
I'll assume a reboot was attempted and did not change anything. I would attempt a repair of LabVIEW from the control panel and another restart.
11-07-2014 12:28 PM
I just ran the SP1 update, so I don't think the repair would help.
I will try it later though.
11-07-2014 03:23 PM
What is the default program that opens VIs? Is it set to LabVIEW or something else? You can check this by right-clicking on the VI file and going to Properties. Under General you should see the default program under Opens with. You can change this by clicking the Change... button. Just a thought.
Also, can you open the VI in edit-mode from LabVIEW (versus double-clicking from your Desktop to open)?
11-07-2014 03:26 PM
Maybe you've already checked this, but this KB talks about setting the VI Properties so that a VI opens in Run Mode:
Setting VIs to Open in Run Mode in LabVIEW
Hope this helps.
11-07-2014 06:32 PM
The poster mentioned deleting his LabVIEW.ini.
11-07-2014 06:34 PM
Yeah, I checked all the options, including the Locked options. Seriously have no idea why this is happening.
11-07-2014 06:46 PM
And that must be frustrating!
To help us reproduce this:
Attach LabVIEW.ini # 3
Actually I'm hoping that you forgot to close LabVIEW before deleting LabVIEW.ini and an obsolete key exists.
