Legacy name showing up in vi top bar
    I have not ran into this before and I am hoping someone has.  The name in the blue bar at the top of the vi reflects a series name that is irrelavent now and I would like it to reflect a name closer to the application.  Does anyone know how to change this name and how is this name gernerated bu Labview?
(2,612 Views)
Accepted by teslac
VI properties -> Window Appearance
(2,601 Views)
I'm not sure to understand the issue correctly, but to chanhe to Window title go to the File menu -> VI Properties -> Window Appearance. You can set the Window Title there (same as VI name check box or use a custom name).
EDIT: I'm a slow typer 🙂
Ben64
(2,596 Views)
