Linear programming
Can Linear Programming Simplex Method VI solve the optimization problem with real value variables (x>=0 or x<0)? If yes, how?
(3,868 Views)
Hi, Thanks for your reply. But in the guidance you provided, Linear programming Simplex Method VI is only used for nonnegitive variables, i.e., x>=0. I am wondering whether the VI can be used for both negative and nonnegative varibales or not. Any suggestion with more details? Thanks a lot.
(3,777 Views)
Accepted by ZDX
Assuming your (potentially) negative variables have constraints (say -1000) you can offest them accordingly and adapt your input data correspondingly.
replace x0 >= -1000 with X0 = (x0 + 1000) >= 0
Don't use negative constraints unnecesseraly big as it may results in numerical issues.
(3,758 Views)
Accepted by ZDX
I've created a quick example (Lv2014) that finds the minimax solution for three equations with two variables.
The solution has both variables negative so using the raw algorithm returns {0, 0}. If you increase the variables offset parameter, the actual solution { -4.86. -0.49} is found for any offset value >= 4.87.
I hope this works for you!
(3,739 Views)
Thanks for your help. It works for me!
(3,678 Views)
