Link Labview and Movicon (a Scada with OPC)
Hi.
I have to read and write some numerical values from a SCADA (Progea Movicon X) and link them to the inputs and output of a fuzzy controller I developed with Labview (7.1).
On Labview side, I can only see Datasocket as a way to "publish" the output value to a Datasocket server and to "subscribe" to it to get the inputs.
Trouble is that in the Movicon list of networking drivers I can't see any Datasocket one. As I know it is OPC compliant, which way I should use to pass those values to and from the two apps?
Considering I have to pass only three integer numbers in total, I would not be too happy if I should spend a lot of money to get the OPC CD servers just for that, so I'm looking for some other way, if any exists.
Thanks.
(2,753 Views)
@fabiospark wrote:
Hi.
If I'm not mistaken, the DS server is NOT an OPC server and DS only supports OPC as a client, so what you might need to do is define the tags in your own server and then write to them using DS. You can also simply bind the tag to a control.
___________________
Try to take over the world!
(2,732 Views)
