09-24-2006 09:22 AM
09-25-2006 09:09 AM
If I'm not mistaken, the DS server is NOT an OPC server and DS only supports OPC as a client, so what you might need to do is define the tags in your own server and then write to them using DS. You can also simply bind the tag to a control.
@fabiospark wrote:
Hi.
Trouble is that in the Movicon list of networking drivers I can't see any Datasocket one. As I know it is OPC compliant, which way I should use to pass those values to and from the two apps?
