Listbox "Top Row" limited to 32k
I built a primitive little scripting language in LabVIEW that makes calls into a state machine.  The listing for the langage is shown in a Listbox control.  As the execution occurs, the listing highlights the current line of execution, and keeps the listing in the window using the "Top Row" property.  All was good.
Then, a very clever user built a script generator.  Scripts can now be exceedingly long, and (despite taking an I32), the Top Row property starts erroring at a value of 32k.
Are there any purely UI workarounds to keep my listbox scrolling?  (I'd rather not have to tinker with my scripting language any more...)
Joe Z.
(3,771 Views)
Try to replace it with a multicolumn listbox. You'll probably have to change some of your code, but the Top Left Visible Cell property takes a U32 and doesn't return an error when you give it a number higher than I16.
___________________
Try to take over the world!
(3,754 Views)
I also tripped over this "limitation". Any chance this gets resolved? The data type of this property is I32 so why limiting to I16? And a note in the documentation also can´t be find.
(3,560 Views)
Probably not, at least as long as NI isn't really aware of it and consider it a bug. I would suggest you go over to the monthly bugs thread in the breakpoint board and add a link to this thread with a brief explanation of the problem. This should get NI to look at it.
Personally, I would agree it is a bug, but a relatively minor one, and I'm not sure increasing the number of rows is a good idea. It's possible that updating the documentation to reflect this limit is the best solution.
___________________
(3,547 Views)
So, I have a similar problem. I have an error when I try to set a value greater than I16 to the listbox "top row" property. I use LabView 2012, version 12.0f3 (32bit).
(3,414 Views)
Then do what I suggested above and use a multicolumn listbox instead.
Another alternative is to hide the scrollbar and create a separate scrollbar control. That way, instead of putting 50k elements in the listbox, you just use the value of the scrollbar to get a subset of the array data and put it into the few elements of the listbox which are actually visible. A bit cumbersome and it wouldn't be necessary if this issue didn't exist, but I would say that a listbox with that many elements shouldn't really exist in the first place.
___________________
(3,395 Views)
Here is an example of how to use a virtual multicolumn listbox.  The same idea can be applied to a normal listbox, but it is basically what tst suggested.  A display of data, that changes as a vertical scrollbar changes to give the appearance of one large table.
http://lavag.org/topic/15289-virtual-multicolumn-listbox/
(3,382 Views)
