Load values txt to a ring
Hi.
I would know how can I load the numeric values that I have saved in a txt and then load them into the values of a ring.
For example.
In the properties of the ring I want the item to be displayed as LOW, MEDIUM and HIGH is what the user will choose.
In each option the value is for example
LOW: 1.2
MEDIUM: 2
HIGH 2.6
These values are stored in a txt. and can be modified.
How I can do so that when the user choose LOW, MEDIUM or HIGH load the appropriate value?
Attachment files
Thanks.
(3,462 Views)
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(3,454 Views)
Hi Steve.
I have clear and put a ring items.
But I want to put the values loaded from a txt.
Thanks.
(3,414 Views)
(3,412 Views)
Hi alberto,
you need to create an array of clusters to fit the datatype needed by that property node.
Just open (and read) the context help to know what you need to create!
(3,402 Views)
Hi GerW
Could you give me an example or guide me a little?
I took a long time stuck at this point and I do not know how to continue.
best regards
(3,390 Views)
Hi alberto,
you need to create an array of cluster of [String, value]:
(3,379 Views)
