12-04-2009 09:18 AM
Please see the attached screen. I cannot find the vi.
Office and report toolkit both installed on this new machine.
Can any one give it, I use 8.6.
12-04-2009 09:27 AM
Which version of the toolkit are you trying to install? There have been updates in the past, some of which were necessary to make them compatible with specific versions of LabVIEW.
Have you checked to see if the LLB is actually there? If so, can you open it? I would recommend that you run a "Repair" on the toolkit installation, or try reinstalling it.
