Locking front panel after one button dialog
Lets say something happens that triggers a one button dialog to pop up which locks everything until you either x out of it or press okay.
Is there a way to keep everything on the front panel locked except for a single button, and the ability to switch between the two tabs that are on the front panel after you x out of the dialog box or press the okay button?
I want to be able to re-enable the front panel only when a certain button is pressed.
(838 Views)
Accepted by topic author Snow1810
Hi Snow,
Sure, each control supports the "Enabled" property!
There are surely better ways to have your users follow certain rules of usage…
(835 Views)
Is there any way you can expand on the enabled state and when to use it?
Also I would 100% agree with you in terms of having the users follow certain rules, however, it is not my call in this situation.
(820 Views)
actually nvm. I understand now.
Thank you for jumpstarting my brain!
(807 Views)
If that dialog is modal, the entire panel of the caller is off limits, enabled or not as long as the dialog shows. You probably need to create your own popup and launch it asynchronously to have full control.
(753 Views)
