Look up table front panel
Accepted by topic author fiatm
You changed the "method" parameter to be from terminal. Highlight the parameter called "LUT X" and then change the parameter source to terminal. This will allow you to wire in an array of doubles for the X values.
Message 11 of 12
(490 Views)
thank you
Message 12 of 12
(468 Views)
