Looking for an example VI that shows how to trigger an event in a VI from a subvi based on a value.
I am looking for an example VI that uses a typical event structure for the GUI, but also has an event that will trigger based on a boolean value changing in a subVI to that VI.
Thank you.
(2,159 Views)
You need to Create User Event.  Any Event structure which is registered with the event, whether it be in a subVI or otherwise can trigger the user event by using Generate User Event.
Right-click an event structure and select Show Dynamic Event Terminal.  This is what you use to register your user (dynamic) events.
Search for "events" in NI examples within LabVIEW.
(2,149 Views)
