Low fps when recording a video with USB webcam
I wanna record and save a video with my Logitech C270 when a certain value changes. For that I've created the VI in the attachment. The VI just works fine with my internal laptop camara, but when I want to record with the webcam, the fps drops significantly and I don't know why. I've already checked the different codeds to use and for driver issues in MAX.
Thanks for your help!
Message 1 of 10
(1,545 Views)
Probably higher resolution with the other camera. Remove the error case and the unnecessary  sequence struture.
Message 2 of 10
(1,524 Views)
Both, my Laptop cam and the C270 have a 720p resolution. Even after removing those 2 things the problem is still there.
Message 3 of 10
(1,468 Views)
Your initialized image is of type U8, is that correct?
Message 4 of 10
(1,458 Views)
Yes it is, for some reason I don't know, it dosen't matter which image type I use, the picture always looks the same.
Message 5 of 10
(1,426 Views)
Adjust your Acquisition Attributes in MAX and save them according your needs.
Message 6 of 10
(1,422 Views)
Try'ed several different settings and lowering the resolution, but it didn't help. As u can see in the VI I've posted, I record picture by picture in a for - Loop at the moment. Maybe this could be the problem?
Message 7 of 10
(1,359 Views)
Did you try the 'Acquire Most Recent Image' example? If the USB cam runs smoothly with different software, contact NI support
Message 8 of 10
(1,347 Views)
Doing it with this VI brings the same results. Will now try to contact the NI support.
Message 9 of 10
(1,337 Views)
Accepted by topic author Spurbruenette
Have tryed it with a generic 1080p cam and now it works properly.
Message 10 of 10
(1,303 Views)
