Managing a webcam using LabView, How?
I have a small webcam (usb) that I would like to use to acquire images through LabView.  MAQ doesn't recognize it and it does not appear on the list of Non Plug and play devices...any suggestions?
Thanks.
(3,391 Views)
Is your webcam TWAIN (http://en.wikipedia.org/wiki/TWAIN) compatible?  You might be able to do it through ActiveX if that is the case.  I would look for an ActiveX or a .NET solution to your problem, I think...
 You might also be able to create a webcam stream external to labview or even the particular computer, and then use an embedded Windows Media Player to stream the feed.
(3,377 Views)
Which version of the IMAQ driver are you using?  Are you using NI-IMAQdx 3.4 or NI-IMAQ for USB?
Alex Person
NI-RIO Product Support Engineer
(3,350 Views)
Accepted by Hummer1
Here is a link to the IMAQ USB software now supported by NI.
http://sine.ni.com/devzone/cda/epd/p/id/5030
Hummer1
(3,278 Views)
