Master Timebase and Reference Clock Sharing
Hello community ,
are the benefits of a master timebase or refernce clock connected to the device series? (For example, E series devices
can only share via master timebases, and M series devices can only share reference clock signals.) My task should automaticly
detect available kind of synchronization and use it. The master (output) uses Master Timebase. The multiple capture cards will
synchonized through the RTSI-line. My idea is to get ProductCategory via DAQmx Device and depending on case select Master
Timebase or Reference Clock. Are there better options ? Is it correct that synchronization with reference clock is synchronized via a PLL with the master and Master Timebase
uses directly the clock of master?
(3,796 Views)
Accepted by VS_03
you got everything correct. Here is a link to a document that explains clocks more detailed:
Synchronization Explained - National Instruments
http://www.ni.com/white-paper/11369/en/
The approach with the case structure, to chose the right kind of synch-rechnique is a good idea for your application.
(3,727 Views)
