Measuring RPM for encoder 11 bits
Here is the result if im using baudrate up to 115200,  You may see the substring format are not according to the format that i set in "scan for string". This error will always pop-out everytime i try to run VI.
Message 11 of 17
(1,419 Views)
You clearly have a meaningful string at 115000 Baud, you just are having problems with Scan from String.  The silly \s "spaces" are the problem.  Try this --
Message 12 of 17
(1,383 Views)
The indicator was already using the \ Codes.  So you don't need to convert the spaces into "\s".  You just need to use actual spaces in the Scan From String.
GCentral
Message 13 of 17
(1,370 Views)
fendy90 wrote:
Argument 3 is throwing the error.  The last VI you posted had 5 items in your Scan From String.  Your read data only has 3.  So you should change your format string to be "%f %f %f".  No need to mention the end of line characters since that is what is causing your error (the function is looking for a space to end the third item and found a carriage return).
GCentral
Message 14 of 17
(1,361 Views)
it is like my data input in substring is intermittent as it read data from the sensor. That's why it throws error in "scan from string". If i used a slower baudrate up to 14400. It seems like the data input stabile and no error for formating
Message 15 of 17
(1,355 Views)
When i force to continue the error, this is what i get from all the input data in substring. It seems like the input data is not stabile.
Message 16 of 17
(1,348 Views)
From your posted example, your encoder values are counting down at a 125ms sample rate. Using my previous posted VI, “Encoder_Accelerometer_Final_Sync_V2_A.vi”, change the logic to check for counting down encoder values and the RPM calculations will work.
If Previous Encoder rolled over or hasn’t changed
Then Delta Enc =(2048-Encoder1)+Previous Encoder
Else Delta Enc = (Previous Encoder – Encoder1)
Message 17 of 17
(1,333 Views)
