10-17-2009 02:53 AM
I have visualisation software written with labview. The local application (created with Application builder) works fine. If i connect with a client (IE8, IE7 and Firefox), the web page is shown, but the controls will not be updated (even if i change a tab!!). Do you have an idear?
biba0507
10-20-2009 07:16 AM
Hi Biba,
just few questions. Have you correctly followed these steps:
How Can I Use Remote Front Panels With LabVIEW Executables?
http://digital.ni.com/public.nsf/allkb/7F95D43D3F50FCAC8625710E000068E1
Is the development enviroment completely shut down whe you run the executable?
Best regards
Andrea P.
Ni Germany
10-20-2009 11:36 PM
Hi Andrea,
thanks for the answer. I found the solution.
I had the problem, that I configured the main VI in the application as reentrant. In this case, it seems that the web server starts a new instance.
After disabling reentrancy, the problem was solved.
regards,
biba0507
