Memory keeps increaing and this VI has a lot of Memory resize allocate events
This aplication slowly increases the memory and after 12 hrs i will get labview out of memory error. With the Desktop Execution Trace Tool kit i found that the Vi(attached) is being called a lot and also has a lot of memorry allocate, free an resize events.
I didnt do this Aplication but i see that the reference is not closed, i dont see any reference leaks on the destkop trace tool kit
do you guys have any idea what could it be?
CLAD, CTD
Message 1 of 18
(4,247 Views)
You won't see the reference leaks until the application exits I believe. Looking at the VI - the reference that comes in on the 'execution' - is that a new reference each time? If so - I think you need to close it. Perhaps also for the 'UIMessage' reference itself?
(blog)
Message 2 of 18
(4,232 Views)
Even though there are a lot of memory events associated with this VI, I'm not convinced that it's the source of your problems. Have you tried running the VI profiler to look at peak memory use for each VI?
Message 3 of 18
(4,204 Views)
let me check at the profiler  and i will get back
CLAD, CTD
Message 4 of 18
(4,197 Views)
After the application finishes and i press quit...
i get all the reference leaks... Thousands of them
CLAD, CTD
Message 5 of 18
(4,169 Views)
Now start closing them.
A few years back I had some memory issues with TestStand references in LabVIEW (Application Instance to be more exact).  NI claimed that the references from TestStand autoclose when the VI step was done running.  I found a ton of memory purely by closing the TestStand references inside of my VIs when I was done with them.
GCentral
Message 6 of 18
(4,134 Views)
Accepted by buton
After 17 Hours and 47 minutes the progam is still running. Those reference were the problem. they didnt show up as reference leaks  on the desktop trace took kit until i closed the program.
thanks
CLAD, CTD
Message 7 of 18
(4,106 Views)
Could you explain what "Now start closing them" means.  I am having a similar problem but not sure how to implement the proposed solution.
Thanks!
Message 8 of 18
(3,867 Views)
"Them" here is whatever references aren't being closed. Make sure your code closes any references that it opens.
Message 9 of 18
(3,855 Views)
CLAD, CTD
Message 10 of 18
(3,849 Views)
