03-15-2016 12:04 PM
Hey guys, I'm attempting to find the damping ratio of a free vibration curve. I'm going to use the logarithmic decrement method. I understand that I need to get the min max of 2 cycles within my FV curve.
How to I "point" to different cycles in my curve? IE. I want to get the min/max of cycle 1 (before the decay), and then the 6th cycle after.
Can anyone give me some direction?
03-15-2016 12:25 PM
Look at the Peak Detector VI. You can set it to look for peaks and valleys. It will give you an array of amplitudes and locations for the peaks (or valleys when you chang the input). Now you can look at your 0th and 5th elements of that array for the 1st and 6th peaks.
03-15-2016 12:38 PM - edited 03-15-2016 12:40 PM
That seems like a good solution...my only problem is that I have many maximum peaks. See pic. How would I go about distiguishing these and only getting the last max? (before decay)
03-15-2016 12:54 PM
I guess I could so some comparison and see what location gives the greatest percentage of deviation between points. Then I would know where my decay starts?
03-15-2016 01:03 PM
That's what I would do.
03-15-2016 01:14 PM
Get the array of peaks. Eliminate the subset where the amplitudes are constant (clipped). Fit an exponential curve to the amplitudes and locations of the peaks. Damping is one of the outputs of the Exponential Fit.vi.
Lynn
03-15-2016 01:17 PM
is there an example on how to eliminate the amplitudes that are constant? Or something similar?
03-15-2016 01:24 PM
Not that I know of.
It is just a basic math problem you are applying to an array of data. You already described what you want to do. See if the current peak is within some tolerance range you define of the previous peak.
03-15-2016 04:39 PM
I guess my problem is my imagination. I understand I need to point to the 0 index and then look at 1 index, and compare the two to see if there's been a 5% change. If there hasn't, go to number 3 and compare with number 2...If it HAS I then pull #2 as my peak. I'm lost when it comes to the code. Would a for loop with indexing be ideal (so I can tie my iterations to my indexes)? Or should I not use a for loop. This array is static...It shouldn't be this hard for me...ugh.
03-15-2016 06:33 PM
Yes. Use a For Loop. You can store the previous value in an shift register.
You've described what you've wanted to do in words, now start laying it out in code and try it out.
You can also use the derivative functions which will calculate the delta between values within the array.
