Min & Max frequency of a waveform in LV 7.1
I have worked a lot with peak detection and find it with some fine tuning to be quite accurate. At least for a relatively stable and noise free signal like yours seam to be. As I understand you do a peak detection in order to find peaks and then calculate the frequency from the time interval between the peaks. Your problem as I understand from the word document you posted first. Is that the peaks are more accurate detected, or artificial peak detections occur.  I you want I can do some test if you send me some data. The simplest way to do this is to copy the chart with data to a new VI then select make current values default. I do not have 7.1 but 7.0 and 8.6 so perhaps save in Labview 7.0
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 27
(1,743 Views)
 so you think the approach can work (zero crossings sounded like it may have possibilities)
 here is the graph with data saved as default
good trick, this is smaller than the tab delimited text file
when I use the Peak Detector.vi  and input a subset of the data (between the cursors) say 4 cycles; depending on the actual window the peak detector might return 4 peaks or 5 or 7(?) At 60KHz the peaks should be about 1000 samples apart, most are but the 'extras'  are only 23 or 71 (or whatever) samples from a true peak. I've tried different values for the 'width' input parameter of the Peak Detector.vi, from 3 to 11 - no real difference that I noticed
thanx
Lawrence M. David Jr.
Certified LabVIEW Architect
cell: 516.819.9711
http://www.aleconsultants.com
larry@aleconsultants.com
Message 12 of 27
(1,741 Views)
I see your problem and with some fine tuning I think I can do something.
Message 13 of 27
(1,740 Views)
thanx for the update, fine-tuning how? there  isn't much configuration
I really appreciate you following through with this,
cell: 516.819.9711
Message 14 of 27
(1,735 Views)
I think I am into something is this correct acording to the data you sendt me?
Message 15 of 27
(1,729 Views)
that would seem to be what I am experiencing - certainly not a smooth response
is that true instantaneous frequency, or is there some sampling error or something?
cell: 516.819.9711
Message 16 of 27
(1,727 Views)
Accepted by lmd2
I think the error is in the main part introduced  during the sampling process. It can be smoothed somewhat, without reducing the peak value to much. But this is the best I can get. With current approach
Message 17 of 27
(1,729 Views)
if I am not being rude, can you explain how you generated these plots. Seems to be instantaneous frequency versus time. very cool
also can you speculate as to what is causing the error in the sampling process?
and thanx again for all your help
lmd2
cell: 516.819.9711
Message 18 of 27
(1,713 Views)
It was not very hard. Here is the code. But now you ove me some beer if I come to your place sometime 😉 I shall speculate during the night and see what I can come up with
Message 19 of 27
(1,708 Views)
not sure of your physical location, but if you find yourself around Manhattan or Long Island, I will buy you several beers!!
cell: 516.819.9711
Message 20 of 27
(1,700 Views)
