Moveable Column Seperators Property
I just completed an exhaustive search of all 4,294,967,296 property indices.  None yields access to the Moveable Column Separators property.
Message 11 of 14
(691 Views)
I would suggest, as Chris had suggested previously, to set the column width and height once the X control is in run time and discard any user changes made thereafter.
Ian M.
Message 12 of 14
(672 Views)
The XControl I'm working on is getting more complicated, and that won't work well.  There is sorting based on mouse down events on the column headers.  So I can't simply ignore any mouse downs during run-time.
I wanted to add a right click option when not in run-time to allow moveable column seperators or not (exactly like the normal multicolumn listbox control has).  I didn't expect it would be this difficult.  It sounds like there isn't a solution that will fit my needs, unless someone can tell me how to programatically call that menu.
Message 13 of 14
(659 Views)
I would suggest using the accumulated column width method I suggested earlier. It sounds like it should be easy enough to implement and you basically just need to get the width of enough columns.
___________________
Try to take over the world!
Message 14 of 14
(653 Views)
